TPI setup procedure?
Ok,
I'm chasing my tail, and wanted to kind of start over. Right now I can't get my IAC steps below ~35 on my SD TPI, and when I turn the screw further, the idle starts jumping up...
I was wondering if someone had a webpage that ran through the setup of a new TPI engine. Example timing set, throttle position, idle, IAC ect.
Thanks for any help!
I'm running a EBL P4 on a TPI intake...
Car: check
Engine: check
Transmission: check
Re: TPI setup procedure?
The ECM may be dropping out of idle mode. Can use the WUD idle indicator to see if this is true. If so open the throttle blades a little via the idle stop screw then start the engine.
RBob.
RBob.
iroc stangs
01-24-2011 02:57 PM
86Tra/maro
05-07-2002 04:17 PM
BLACK Z
Carburetors
06-02-2001 07:07 PM
formcam
09-14-2000 10:26 AM
