TPI DataMaster users, which is the BLM?
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
For a '92 TPI setup, using DataMaster 8D, which field should I use as the BLM cell?
There is the "Long Term C-Counts" and the "Long Term Adj" field, the C-counts field never goes below 108 and does not change often so I think it may be the actual BLM, the Adj field seems to be just slightly higher than the Short Term C-Counts field which would be the INT, and both change very rapidly.
Help text says "LTerm Trim" which there is no field labeled this and it says its expressed as a % from 128, which it is not, its the actual number, so the help text is not correct.
Re: TPI DataMaster users, which is the BLM?
but as Synapsis said, Long Term Counts.
BW
The same can be said about almost all software doc in that there's always something not documented right.
But I am very happy with the software, just glad we have these bulletin boards to get the real answers the sw companies/writers can't provide
Car: Sexy
Engine: Stock
Transmission: Slipping
As a software developer I'd like to say:
We hate writing help files.
It's usually the last thing we do and unless there's a team of people doing it, it almost never gets really completed.
It's usually the last thing we do and unless there's a team of people doing it, it almost never gets really completed. Thread Starter
It's usually the last thing we do and unless there's a team of people doing it, it almost never gets really completed. In a side note it become very easy to tune the BLM's if express them as a percentage off of 128. That way if you use trax's meathod of adjusting the VE tables, you don't have to convert the BLM's first. It's hard for me too look at strait BLM's anymore, I feel so much more comfortable seeing the percentages.
hth,
Jim
Thanks Jim, didn't realize I could do that, its been a long time since I configured the DM software for the setup.
I will change it as I just finished "round #2" for going thru the VE tables and doing the conversion, I've almost got all the conversions to % memorized based on the BLM value now
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
... and I'm guessing that for TTS Datamaster, that "STerm-C Counts" (short term counts?) is the INT. of course, this isn't mentioned anywhere in the DM Help.
I wasn't sure if I saw that explicitly stated anywhere, although by process of elimination one could conclude that ...
at least, that's the assumption I've been using while messing with my VE tables. it sure would be awful to be wrong at this time. although it might explain why I'm still not tuned in.
1992rs/ss
16
Jan 28, 2016 09:58 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
Sanjay
Aug 12, 2015 03:41 PM
