Glenn
Glenn
I posted this because there is no private way to contact you. Last year you implied that MAT (for 165 ecm)was doing more than just egr control,yes? If so then could you explain?
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Re: Glenn
https://www.thirdgen.org/techbb2/sho...hreadid=214156
Tim
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Where is the implication about MAT ('165 ECM) controlling anything but EGR enable? I remember reading the threads last year, but I only remember that tuning/recalibrating the MAT was only important for EGR.
Anyone?
Anyone?
Car: An Ol Buick
Engine: Vsick
The 58 code gives you meaningful MAT corrections, but that's 730/749 stuff. Maybe a look at the Australian 808 stuff might be helpful, for the 165, thou just off hand I don't remember it using the MAT.
Glenn, you have not responded. I hope you are ok. When I started prom burning you was the guy that made me feel comfortable. To be honest, I really looked up to you....
I really wonder what happened
Car: Death Mobile
Engine: 666 c.i.
Re: Glenn
Car: 81 Turbo Trans Am
Engine: 301 T
Transmission: 200-4R
For MAF systems, the theory is that air temperature is compensated in the MAF reading itself. If the sensor is, in fact, sensing *mass* of air, this make sense. In speed density systems, we need to know temperature to determine the mass of air via calculation rather than direct measurement.
Not me.
