Eproms corrupting, only in a 1226870 (85 TPI ECM)
Ok this is really weird...
I have used 2732A's, 28c64's, 27Cxxx and 29Cxxx's before in a few different GM ECM's without a problem.
For many months in my own 7747 I used 28c64's instead of the original 2732's by making an adaptor as described by Ken73 in this thread:
https://www.thirdgen.org/techbb2/sho...ighlight=28c64
Basically, it looks like this:
I have now attempted to use this mod (again in place of a 2732) in 2 different 85 TPI (1226870) cars with the same WEIRD results! The cars start and run fine, but anytime between 5 mins and a month later, they give a code 51 and go into limp mode! When i pop the chip back in the programmer, the contents have changed!!!!! I have tried with 28c64, 29c256 and 27c256, all failed eventually!
Should i be grounding the 2 unused pins at the top end of the larger chips?? Are they seeing a floating voltage??
Can anyone take a guess as to what is going on here??
Thanks,
Ben.
Thanks,
Ben.
1 Post
Car: An Ol Buick
Engine: Vsick
Re: Eproms corrupting, only in a 1226870 (85 TPI ECM)
Thanks,
Ben.
Thanks,
Ben.
Re: Re: Eproms corrupting, only in a 1226870 (85 TPI ECM)
Originally posted by Grumpy
Obviously the 6870 doesn't like EEPROMS, since it's a MAF type system, so it should be updated to a MAP or MAP/MAF hybreed system. Perferrably the later.
I'd really like to find the problem.. Last resort will be to convert to a '7165.
Car: check
Engine: check
Transmission: check
CMOS devices are required to have all unused inputs tied to either ground or VCC. Otherwise they oscillate like a leaf in a hurricane.
RBob.
RBob.
RBob.
RBob.
One quick question. I looked up the datasheet for the 28c64 at http://www.atmel.com/dyn/resources/p...ts/DOC0001.PDF
One of the overhanging pins is WE (Write Enable).
The datasheet says on pg3, under "WRITE PROTECTION" :
– holding any one of OE low, CE high or WE high inhibits byte write cycles.
Is this correct?
Much appreciated.
Car: check
Engine: check
Transmission: check
RBob,
So i am guessing I should be connecting WE to Vcc to ensure the chip contents are stable???
Is this correct?
Much appreciated.
RBob,
Is this correct?
Much appreciated.
RBob.
Sanjay
08-12-2015 03:41 PM
