$58 TCC control
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
$58 TCC control
How does the TCC lock control tabels work in $58?
Trying to set the values for max performance.........
/N.
/N.
Car: 81 Turbo Trans Am
Engine: 301 T
Transmission: 200-4R
Kind of a wide open question there.....
Among the things you have to play with :
1) Coolant Temperature enable of entire algorithm
2) Delays for TCC lockup
3) Both positive and negative TPS "deltas" to unlock TCC
4) TPS vs. MPH tables to enable/disable TCC
Do you have some areas you definitely want (or don't want) the TCC to engage? If so, I'm sure we could come up with a set of calibration values to get you where you want to go.
Damon
Sep 26, 2015 04:29 PM
