How do I correct Fuel Cell Knock Counts?
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Unsure why I am getting knock Counts
I have been playing and datalogging this for some time. I initially thought that I might have a sticking valve or something loose in the engine. After running datamaster for the 1000 time, I found something that maybe someone can explain how to correct. The car has a really good idle. Every now and then I noticed it retards the timing and it spits out a knock count. Does anyone have any ideas? I readjusted the valves which didn't help. I see that I am running just a tad lean. I have inclosed the last log from Datamaster and I would appreciate any ideas to fix this.
This autolog004.doc file must be changed to autolog004.uni for datamaster
355 TPIS
42 LB Ford Injectors
355 TPIS
