Stroker Idle problem
Old Sep 18, 2009 | 01:06 AM
kevinrdyck32's Avatar
Hello all. My father bought a 305 tpi out of a 1987 Iroc. He had it bored and stroked to a 355 I think. But any ways it runs good, until it warms up and then driving down the road when he puts the clutch in to stop 1/2 the time the engine stalls. It only does it when it is warm. Now my dad did put the proper fuel pump and proper injectors. But he has not had the stock chip looked at yet. It is in his jeep by the way. Any help would be great from you fine folks.
Old Sep 18, 2009 | 07:10 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Stroker Idle problem
It should have a VSS feed to the ECM. Being a swap it may not.
Another item is the park/nuetral input to the ECM. This needs to be left open, not wired to anything.
Clean the IAC and TB, then check/set the minimum air and TPS value. The procedure for this is in the tech articles. Link is found on the home page here.
RBob.
Old Sep 18, 2009 | 02:02 PM
Thanks for your help. But I am stupid when it comes to this stuff. so what is the ECM and the VSS.
Old Sep 18, 2009 | 06:48 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
https://www.thirdgen.org/forums/diy-...uide-book.html
https://www.thirdgen.org/forums/diy-...ns-sticky.html
To be honest, spend some time with your dad working on the TPI setup. With him doing the swap he will know what a lot of this stuff is. At the same time reading the above links (second one first) will help a lot.
RBob.
Old Sep 20, 2009 | 06:30 PM
Ok I have talked to my father. we do not have a VSS on his jeep. So what should we do then.
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
