$8D-Turbo bin development thread
#102
1 Post
Car: '74 Firebird, '84 vette
Engine: 454 twin turbo, 350 HSR
Transmission: 4L80E, 700R4
Axle/Gears: 9", Dana36
Re: $8D-Turbo bin development thread
I read a few posts up that you are looking to add flex fuel support.
The speeduino project added it several months ago to their arduino based EFI controller.
The code is available on github and is really simple. Adapting the concept shouldnt be too hard.
#103
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
I'll look into it to see if they've done anything interesting. Thanks for the heads up.
I also could add Flexfuel functionality without the NVSRAM but the NVSRAM makes it more fun for me being all coding.
#104
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
guess it don't matter no more, took the air filter off the procharger and the bolt for the impeller fell off chewed up the impeller good. corvette time
#105
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
Corvette is a good call. Might as well keep the thirdgen though, just park it somewhere and never drive it like me. Nobody will pay you anywhere near what it's worth if you try to sell it.
-- Joe
#106
Car: 1986 Camaro SC
yeah the bolt and that weird bevel washer came out, i can clearly see locking compound on the threads. procharger says the only thing they can think of is the heat made the locking compound fail after a while
#107
Engine: LB9
Axle/Gears: 3.08
Added two "new" features.
Made the highway mode automatically on and aggressive.
Eliminated the "paperclip trick" diagnostic readout. Now with the Drivemodes switch I added you only need to change to mode 0 (injector Killswitch) to read codes.
#109
Engine: LB9
Axle/Gears: 3.08
In tunerpro you can set up new scalars at the address locations I posted. Then make sure the value I said is there actually is. Then you edit it to the 3 bar values I posted, save, burn, try it out.
You can also use the hex editor feature in tunerpro and do the same thing.
It's really quite simple. But you will want to be VERY careful running this as its untested under boost.
Eventually I'll add these scalars to the XDF I posted to make this a switchable map sensor setup for anybody that can alter a tune.
#110
Car: 1986 Camaro SC
3 bar values:
scalar: 210 = 0x00D2
Offset: 921 = 0x0399
so i can make a new scalar anywhere in the scalar list edit it and add the hex address 0x00D2 what is the 210 mean? and what is offset?
#111
Engine: LB9
Axle/Gears: 3.08
Scalar and offset don't matter for you. Just enter the hex 0x000 style number at the addresses.
The numbers are the actual values of the hex you're entering.
#112
Engine: LB9
Axle/Gears: 3.08
Locked BLM at WOT now.
More to come, but very slow moving. 3 jobs and 2 kids keeps me even busier than before.
#113
Has this project totally died? I'm trying to figure out the engine management strategy for my '90 Corvette I'm about to boost, and was very excited to come across this thread.
#115
- Has to be easily revertable to stock or visually similar so I can pass CA smog
- Has to preserve ECM/CCM comms so the dash MPG display works
- Has to be able to run a flex fuel sensor
- No lift shift would be nice
- Ability to control a wastegate and possibly water injection pump would be nice
#116
Engine: LB9
Axle/Gears: 3.08
I'd offer to test, but I'm a long way off from boost. Right now I'm just making sure there's a good solution for engine management before I pull the trigger on a Procharger kit. Right now I'm leaning toward piggybacking a standalone (probably MS3) on my stock ECM, but I think this code would do the trick. My main requirements are:
Flex fuel I'm going to be honest, probably not going to happen at this point. There's no E85 near me anymore so I have lost interest in it.
Really not hard to do. Run a repeating cycle to check fuel trims every few minutes, adjust and store a multiple to correct fueling across the board instead of just closed loop.
Also the same way can I planned to be done to automatically adjust the entire timing table up or down until it knocks or until an acceptable threshold of knock. Recheck every so often at WOT.
No lift shift, is not necessarily impossible but can't be implemented in an ideal way as the computer has no idea when the clutch is engaged and it's not a drive by wire car.
Wastegate control I had planned too but the longer this turbo sits on the shelf the more I realize I won't ever get around to doing everything I wanted and it would have required an arduino anyway so that can still be done by somebody and used at the same time.
#117
Well, The code is pretty basic work. It's got extended tables and MAF ranges so it might be ready to go as-is with basic tuning. It's a tune so everything else is as it is now. Swap the MAF and off you go.
#119
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
Mark.
#120
Engine: LB9
Axle/Gears: 3.08
Hey, currently I'm pretty removed from the project, but not permanently abandoned. Just way down on priorities list right now.
I don't remember any switches for that, but it's been quite a while since I set this up. I am pretty sure it's the same code I've been running since posting and that's the exact xdf file I used. I think I was pretty good at posting about implemented changes on what was altered so that people could use and adapt to my work very easily just from this thread alone. It was an incredibly simple set of changes. The crazy stuff was mostly in my head or hidden in the code and not defined and maybe not even posted. Again, I don't remember! But it is disabled if not in the XDF.
Just take it easy and go slow with the boost until you've fully tested it or run into issues to be addressed.
Don't really know if this helps but hopefully it's something!
#121
Engine: TPI(s)
Thanks for the efforts invested!
Mark.
#122
Engine: LB9
Axle/Gears: 3.08
For sure it's been a few years. I just wasn't sure if the BIN worked with 1 BAR or 2 BAR map ... or always 2 BAR. I"ll guess the later and see how it goes. I've used the 12p code on a 165 ... slow process to dial it in, but it does work.
Mark.
Mark.
Should be very easy to check/edit with what I posted.
#123
Hey, I need some help. I have a 406 SBC, tuned and runs perfect on a 1 bar with S-AUJP. I recently added a Turbo, hot and cold side is all done. I have a 2 bar map and need a way to tune it. I'd like to stock with $8D becasue I spent alot of time getting it to run Nortstar DIS and control my fans, speed-o perfectly. Any help will be appreciated.
#125
Engine: LB9
Axle/Gears: 3.08
ive been running this since the threads inception. BUT the turbo is still in its box. Real estate is more fun right now.
#127
Engine: LB9
Axle/Gears: 3.08
Lost all of my personal disassembly on this stuff so I am reverse engineering my own work right now. I've realized that the Scalars and Offsets above are incorrect. I've got new values and I'll update them up there.
I also have updated the tunerpro file to allow quick and easy scalar and offset changes for anybody that wants to run any MAP sensor with this.
Pretty easy to reverse engineer my own work, but I've forgotten a lot of the stuff I hid in there. All I wanted was to tune my car and here I am obsessed with this again...
