Ostrich 2 issue w Cyl Select
I have used Moates Ostrich 2 for years and have never run into this problem.
Pulled the Ostrich from my 92 LT5 and sent it to a friend to install in his 90 LT5. Loaded a stock bin file, and Code 41 pops up. When I insert the stock prom from where I read the calibration that was then loaded into Ostrich, the original prom works fine. No code.
Re: Ostrich 2 issue w Cyl Select
It appears the calibration is operating normally even w the flag being set. So we’ll see if deleting the flag has any effect.
I un-set the Code 41 MALF, and that appears to have worked. No other issues. Car drives fine and calibration working as expected. Its a bit puzzling what the problem is.
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Had that code twice, both times my chip was loose in my adapter and not by much
got a new adapter and all was fine
Need to check w different prom.
In the meantime, I UN-set the Code Flag for this w no detrimental affect.
apache3132
07-26-2008 08:23 AM
