86 Camaro 305 TP1
Re: 86 Camaro 305 TP1
Thanks for your reply.
I have used a $32.xdf file and have since found Fuel Cut off at 255mph which is good.
So on my stock 305 TPI it is fine to upgrade tune to $6e ? . Apologies for noob questions as my prior tuning experience is with Nissans !
For $6e you need to see if the fan switch setting is normally open or closed.
You will also need to disconnect the ninth injector.
http://www.gearhead-efi.com/Fuel-Inj...Information-6E
retro-roco
09-11-2016 01:46 PM
