Engine Swap (305 to 383) PROM Programming
Car: Maroon 1991 Camaro RS w/ T-Tops
Engine: 305TBI (Soon to be 383)
Hi All, just a few questions on what to change when getting into PROM tuning.
I have a 1991 Camaro RS, airbag, ac/heat, electric windows, tbi, all the fun stuff.
I have the original PROM $61 and I was wondering which flags I have to change during the engine swap. I will be changing from TBI to FiTech EFI and using an additional fuel pump, removing the charcoal canister and the cat as well as replacing the exhaust headers (currently have some vacuum? lines running on them). The FiTech system self tunes the air/fuel ratio with it's own computer and o2 bungs.
Any help in the right direction would be great, thanks!!
I have TunerProRT and a MiniPro Chip reader/writer.
I also have additional new chips from this guy on ebay:
https://www.ebay.com/itm/Major-Brand...-/122289434971
Below is just a picture of the start to my adventure of a swap lol
Re: Engine Swap (305 to 383) PROM Programming
You might want to start with anlu and recurve the sa.
Adjust bow then start tuning ve.
There is a lot of information on $61 tuning here
https://www.thirdgen.org/forums/diy-...uide-book.html
@TunedPerformance Thanks for the reply! My apologies, Spark advance is also handled on the FiTech system as well (msd ignition box). I guess the better question here is: which flags do I have to disable to remove check engine lights
Not sure what your asking if your not using $61 mask you won’t have any malfunctions. Unless you removed the egr and need to max the egr speed on and or malf switch 32. To disable the check engine light cut a5 brown white wire at the ecm.
My90Iroc
04-29-2003 07:35 PM
