tuning question
Car: 1986 Trans AM WS6
Engine: 383 Vortec TPI, PUTS SMILES ON FACE
Transmission: PATC LVL 3 Raptor Transmission
Axle/Gears: 3.27 POSI 9 BOLT
tuning question
so my maf is bad but was wondering if im able to still tune with the maf unplugged? or is that considered limp home mode? and if so I thought limp home mode will only work a certain number of times and than not allow you to drive it anymore, (not sure where I read that)
im just running very lean at idle and rich at WOT.
Car: check
Engine: check
Transmission: check
Re: tuning question
RBob.
Re: tuning question
thank you... im using the $6E bin, so look at the rpm vs which tbles,, im going to check it out when I get home... just don't like it running 17-19 afr while idle or come to a stop light., that to me is dangerouse... while im cruising its 14.7-15.0 and wot is 10.9 or so afr.
Re: tuning question
so it slowly kills your car when in limp home mode... that's gay
327_TPI_77_Maro
11-20-2004 05:06 PM
GASGZLR
Carburetors
02-28-2004 03:15 PM
