7747 problems
7747 problems
Here's the basics:350 Chevy crate (10067353), GM Crossfire, 1227747 with 28 pin zif socket(http://www.gearhead-efi.com/Fuel-Inj...sh+conversion), Moates APU1(autoprom) and chips, BIN ARHT, $42. Trying to bench test the ECM before I install in vehicle. I verified ground at the ECM and the manifold/injection assembly, then applied power to B1/C16. Then supplied power to A6, SES lamp, and ESC module. The SES light never flashed when energized, I dont show a voltage reading on the Tuner Pro RT dashboard, or a 5v reference at the TPS or MAP sensor. Touching the ses wire to the ECM case will light it so the ecm is not sending a ground out to A5 upon power up. Have tried with and without a chip in the ECM. Is the ECM dead? Also how do I verify the BIN is installed on the chip correctly (offset) or is it automatic with the APU1? 28 pin conversion socket was checked for continuity and tested ok. . Any help is appreciated. Thanks, Cal
Car: check
Engine: check
Transmission: check
Re: 7747 problems
Either the ECM is dead or the chip socket install was botched. With no PROM installed and the ECM powered up the SES light should flicker rapidly. If not then something is wrong with the ECM.
RBob.
RBob.
