Using EBL flash with USB serial Adapter
Car: 83 GMC G3500
Engine: 350 w/ EBLFlash and TBI heads
Transmission: TH400
Axle/Gears: 4.56
My USB serial adapter is a HP P/N 5184-2238 I’m trying to use it with my EBL flash.
Looks like it uses a FTDI chipset looking at it in device manager , Are most USB serial converters using this chipset the same?
Also the original cable is missing can I use a 6’ phone cable between the EBL and the serial to RJ11 converter?
thanks
thanks
Car: check
Engine: check
Transmission: check
Re: Using EBL flash with USB serial Adapter
thanks
thanks
RBob.
