Data stream file
Car: 91' Formula/88' Formula
Engine: 5.7L TPI/ 5.7 zz4 with mini ram
Transmission: 700r4/Stock T5
Axle/Gears: 10 bolt 3.23 /9 bolt 3.70
Data stream file
Hi everyone
I need an adx or ads file for data streaming 86 and 87-89 tpi engines for tunerpro Moates download doesnt work and i cant find any where else. Please help
Re: Data stream file
http://tunerpro.net/downloadBinDefs.htm#GM
They're .ads files, so you'll have to do an Import from the Aquisition menu from within Tunerpro. Then save it as an adx. After which point you can open it back up through the Load Definition File.
Hi Thanks for the help, but its nit working for me i downloaded ads files for 90-91 tpi and truck tbi they work fine but 86 and 87-89 ads files on tuner pro are links not files,.
open it as a text file, then within the page, right click, save as... it should save as a text file, but have a .ads suffix. Once it's on your hard drive, do the import I mentioned above.
Thanks very much for your help. much appreciated (you have to right click the link before opening the page) it worked..
