Problems with headlights
Old Sep 25, 2000 | 08:23 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
I have a problem with my driver's side headlight. When I turn on the headlights the passenger light comes up with no problems. But the driver's comes up about 3/4's the way up and starts bouncing up and down. Sometimes it will only come up half way. I've already changed the motor once. It corrected the problem for a short while then the problem returned. I am stumped. Any help would be appreciated.
'91 GTA with TPI 350 & T-Tops. Just a few mods, if you want to find out just line up next to me at a stoplight!
Old Sep 26, 2000 | 08:51 AM
scauffiel's Avatar
Take it apart and check it out. Open the casing with the gear wheel; if one side is stripped of it's teeth - flip it. If that's okay look on the backside of the wheel, you will find three "rubber" ***** - or maybe you won't. If those have powdered, replace them with .504" (IIRC) steel ball bearings. I did this over a year ago and have had no problems since.
Steve
Old Sep 27, 2000 | 12:19 AM
I did take it apart a while ago. The teeth were fine. I don't remember seeing any rubber bearings on the backside of it. If that were the problem, why would two seperate motors have the same identical problem. The second one was fine for a few months before it started doing it. Also, sometimes it seems to help if I turn on the fog lights first before I turn on the lights. Do you think it could be my relays? If so, how do you fix them?
Old Sep 27, 2000 | 12:22 AM
I forgot to mention that the motor on the driver's side turns for an extra ten to fifteen seconds after the passenger's. The passenger's pops right up and the motor stops turning whereas the driver's continues to turn for the extra time.
Old Sep 28, 2000 | 12:11 AM
Anybody help me?
Ghettobird52
Jul 5, 2024 11:18 PM
GTAman
Mar 15, 2019 11:40 AM
DiabolicalRS
Aug 26, 2015 07:35 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
