Fuel Pump
Old Nov 3, 2000 | 03:30 PM
SeanSullivan's Avatar
Fuel Pump
Tried this on the carb board with no response, maybe better luck here.
IF I convert from TBI to Carb, then remove the ECM and Chip, will the fuel pump continue to work as it did before? ie.. with the key on, and so forth.
Its on a 92 RS was tbi, now carb.
Old Nov 4, 2000 | 10:22 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
You will need to retain the fuel pump relay and the fuel pump oil pressure switch (located within the oil pressure gauge sending unit). The fuel pump relay is normally controlled by the ECM, but you will need to connect it to the start circuit, in your application. Connect the dark green / white wire from the fuel pump relay to the purple wire going to the starter solenoid. In this configuration, the relay will power the fuel pump during cranking, and the fuel pump oil pressure switch, which parallels the fuel pump relay contacts, will power the fuel pump while the engine is running (oil pressure > 4 psig).
Tim
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
