Custom Chips
Old Mar 24, 2001 | 07:29 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Custom Chips
I have read that when you remove the smog pump the computer can think that it is using EGR but it isn't. Can a custom chip "tell" my computer that I don't have any smog stuff?
About how much do custom chips cost?
[This message has been edited by brodyscamaro (edited March 24, 2001).]
Old Mar 24, 2001 | 08:00 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The ECM has no input from the air pump. The air pump output goes through two valves, which are computer controlled. If the valves are disconnected from the harness, the ECM will set a code, because it thinks the valve coils have opened. The air valve error codes may be disabled in the PROM. The air pump has nothing to do with the EGR valve. The EGR valve is vacuum controlled, and the vacuum is controlled by a solenoid, which is computer controlled. If the EGR solenoid is removed from the harness, the computer will set a code, for the same reason listed above. The EGR diagnostic may also be disabled in the PROM. I've seen custom chips range anywhere from $100 to $600, depending on the vendor. You have some options, if you want to retain your stock chip, though, & not get any codes set. You could leave the harness plugs connected to the three solenoid valves, or you could disconnect any of the three solenoid valves from the harness & put a 1K ohm 1/4 watt resistor (from Radio Shack) in place of the solenoid. This will make the computer think that the solenoid is still there & it will not set a code.
Tim
Old Mar 24, 2001 | 09:08 PM
Thank you for the advice! Are you saying that the AIR pump is not used in the EGR system? For instance could i remove my smog pump and keep EGR?
Where can I go on the internet to get quotes on custom chips?
Old Mar 25, 2001 | 02:11 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Ed Wright at www.fastchip.com or burn your own.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
[This message has been edited by Kevin91Z (edited March 25, 2001).]
Old Mar 25, 2001 | 10:06 PM
Yes, the air injection system and the EGR system are separate independant systems, and one may be removed without removing the other.
Tim
ramicio
Sep 28, 2015 01:18 PM
Deemax
Sep 12, 2015 06:53 PM
Ranbo108
Sep 9, 2015 12:20 PM
TBRays98
Sep 6, 2015 05:05 PM
