Need a little advice
I bought a Led Air Fuel Guage from summit. It came in the mail yesterday. I was looking at the directions and it seems straight forward. Red 12+, Black Ground, Gray oxygen Sensor.
Here is my question. Do I have to get the gray wire from the sensor itself or can I get it as it goes into the computer? I looked in my Manual and it said that wire D7 (purple)was the sensor. Should I grab it there or at the sensor itself? Also Where can I get a 12 volt positive that is only on when the ignition is?
Thanks for any advice
Bill
Bill
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
BILL
I just installed mine today as well I got power from my cd player and all you need to do for the Sensor I just splice into just before the connector to the Sensor (not the sensor side) I did mine just like 2-3 inches befor the Conector
It all worked out fine
Hope that helps
Hecubus
Check out my new site http://www.geocities.com/hecubus91
91-Z28 305 Tpi "G92" mods-- K$N/Foil/Cat Back 3" Flowmaster/3" High Flow Cat/B&M shifter/ Intrax Springs/ Kyb Shock's-Struts's/Poly Bushings/Hotchkis Strut Tower Brace/ 100-150 Nos Wet Plate System/ 155lph Fuel Pump/ Holly Adj. Fuel Press. Regulator/Digital Fuel, voltage & Oil Press Guage's/MSD 6al/ Blaster coil/ Optima,Yellow top batt.
"I spent all my money on race cars, beer, and Broads... The Rest I wasted"
Hope that helps
Hecubus
Car: 91 z82
Engine: 5.0
BILL
I ran it threw a hole in the fire wall (much easier that way) just underneath the Power Brake Booster and all that... and then put it in a Loom and ran it to the "Black" wire just before the connector
you can email me I'll be happy to help with anything futher
Hecubus
91-Z28 305 Tpi "G92" mods-- K$N/Foil/Cat Back 3" Flowmaster/3" High Flow Cat/B&M shifter/ Intrax Springs/ Kyb Shock's-Struts's/Poly Bushings/Hotchkis Strut Tower Brace/Nos Wet Plate System currently ~200hp shot/ 155lph Fuel Pump/ Holly Adj. Fuel Press. Regulator/Digital Fuel,Air-fuel, voltage & Oil Press Guage's/MSD 6al/ Blaster coil/ Optima,Yellow top batt.
Hecubus
HoosierinWA
Oct 7, 2015 10:15 AM
