system problem..
Old Apr 26, 2001 | 11:10 PM
Slow83Z28Camaro's Avatar
system problem..
im installin a system rite now and so far i have my radio,speaker wires hooked in, now i need the big red cable wire runnin through my firewall, does any 1 know were i can stuff this red cable through my firewall? i have a 83 z by the way.
Old Apr 28, 2001 | 04:47 PM
thickfacek's Avatar
I ran into the same problem when i installed my system in my 1990 iroc. I ended up running my power wire through the passanger side fender and through the hinges of the door and then into the interior. Kinda hard to explain but it worked. I had a 1991 RS before the iroc and i had to drill through the firewall because the battery in that car was on the driver side. So it really depends on what side your battery is on and how much wire you have.
> 1990 IROC-Z (black)
> one of 3000 IROCs with a 305 made in 1990
> flowmaster exhaust
system with mufler bypass
> z-28 spoiler
> blue under car neon kit
> check out my site at: http://geocities.com/thickfacek/IROC-Z.html
> email me at thickfacek@nc.rr.com
Old Apr 28, 2001 | 11:25 PM
Belker's Avatar
In my 91 RS I had to drill a hole throught the firewall. If you do this make sure you use some type of grommet in the hole. Also, make special effort to locate the hole so that it is as far away as possible from your exhaust manifold (I didn't consider this when I drilled mine and ended up having to make a heat shield in the engine compartment).
Old Apr 29, 2001 | 02:22 AM
KenGTA88's Avatar
In my 88 GTA there was an existing rubber grommet somewhere above the brake pedal. On the engine side, the hole is just below the master cylinder. The hole already has stock wires running through it and it was big enough for me to run a 4-awg power cable for my sound system through it.
Old Apr 29, 2001 | 01:50 PM
thanx for the help guys, i drilled a hole in the passenger fender firewall thing, and ran it through under my fender , now i need some dynomat so the trunk wont rattle
Old Apr 30, 2001 | 12:51 AM
Hummer's Avatar
Car: 1986 Z28
Transmission: 700-R4
Try your system out before wasting money on Dynomat. That stuff is expensive and I'm not really a fan...I just tightened up some loose bolts, used some silicone and tape, and I really don't have any rattles any more. My plate was bad, but I just needed a new retaining clip. The lights in the back can be a pain too...once again, silicone. Just my opinion.
jrdturbo
Mar 31, 2016 02:58 PM
1992Z28!
Nov 19, 2015 07:33 AM
Night rider327
Oct 9, 2015 09:25 AM
Night rider327
Sep 25, 2015 04:47 AM
reactor60
Sep 22, 2015 01:44 PM
