Fuel Pump
Old Jun 13, 2001 | 06:53 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Fuel Pump
My fuel pump doesn't turn on when I turn the key to "on" position? It used to turn on then my VATS screwed up. We took the car to a mechanic who says he checked everything and then he tried to start it. The fuel pump didn't turn on so he sprayed carb cleaner down the throttle body. Ever since then the fuel pump hasn't turned on when the key is in the "on" position. Any ideas, I appreaciate any/all help!
Old Jun 13, 2001 | 08:20 PM
Camaro_hunter_d's Avatar
fuel pump relay. pasanger side fender...
Old Jun 13, 2001 | 08:58 PM
Replaced it already, actually both of those relays, and the pump, and the tank, and the sending unit. Most of this stuff is new in good condition but now my only problem is the pump won't turn on
Old Jun 15, 2001 | 03:26 PM
MAXGTA2002's Avatar
check the fuse by the battery it might be blown. if it has one, a orange and black wires.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
