A/C Help
Old Jun 19, 2001 | 08:53 PM
POS Camaro's Avatar
Car: 1986 Camaro Z28
Axle/Gears: 3.73 Posi
A/C Help
I have a minor problem with my A/C. The compressor will not turn off with the switch in the car. The clutch is not frozen, it is disengaged if the connector is removed. If I remove the A/C Fuse, there is still power to the clutch. If I remove the Choke Heater and The A/C fuse, all power is removed from the clutch connector. I replaced the throttle kicker relay, where the choke heater and the A/C both have power. The diode across the clutch connector appears to also be bad. I don't think this is the problem though. Anyone with ideas, please respond. I am hoping for common components, and search for a short in the wire bundle won't be fun. Removing the connector from the low press switch also does not turn off the compressor.
1985 Camaro Sport Coupe
LG4, 3.08 rear, A4
Bone Stock
1999 Blazer
4x2, 4.3L, 3.42 rears
Decidedly slow
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
BLK87Z
Sep 18, 2015 11:29 PM
Mdenz3
Sep 17, 2015 08:36 AM
