How do I remove the turn signal arm?
My cruise control is acting up, it goes to full throttle every time I slide the switch over to the ON position, and I think the switch at the end of the arm might be bad, how do I take it off so I can check it out? Would there be another reason the cruise would do this? Thanks
92 Camaro RS 5.0 5-Speed
L98 Alu. Heads
SLP coated headers
Dynomax cat-back
14" open air cleaner
1998 Dodge Ram SS/T
L98 Alu. Heads
SLP coated headers
Dynomax cat-back
1998 Dodge Ram SS/T
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
You can check out the functionality of the switches with an ohm meter without removing the arm. However, to remove the arm, put the washer switch in the "off" position & pull the lever out of the column.
Tim
1992 Z28, 305 TPI 5 speed, 12.1 sec @ 114.7 mph
1984 Berlinetta 305 TPI Auto, 13.8 sec @ 99.7 mph
Tim
How can you use an ohm meter to check it? I pulled the cruise control module and probed the plugs to check for voltage from the switches, and got no response. Is there a place closer to the actual switch which I can probe to check their functionality? Currently I get absolutly no response from the cruise control, but all the vaccuum lines look fine, and the pedal switchs ect. have all been checked. So how can I check the m/f lever?
- Mike
- Mike
Fronzizzle
Mar 18, 2019 08:29 PM
