Useing A/c switch to turn on fan...
Old Aug 18, 2002 | 12:23 PM
Jokerman's Avatar
Engine: slowtacular L03 305
Transmission: slushem 700r4
Ok, my a/c compressor shot craps (the clutch was toast to begin with) so i took it out and replaced it with a pully. I have been useing the a/c selections on the heating/cooling controls to turn on the cooling fan in a somewhat manual fashion. Is this going to cause something to burn out or is it fine and saveing me the effort of wireing a manual fan switch for myself.
Old Aug 18, 2002 | 05:54 PM
Mr300's Avatar
what happened to yours when it burnt up? lately when i turn off my a/c smoke will come out of the vents or out of the part with the 2 switches (the switches that you slide from left to right). i have also been using my a/c at the track to cool my car down. i unplug it and just have the fan running all day. i wonder if that is what is making it smoke and go bad.
Old Aug 19, 2002 | 10:55 AM
Jokerman's Avatar
Well when i found out the clutch was bad it would smoke with the a/c on (the previouse owner had drained the system so we filled it). The bearing in my compressor went out so it was starting to make alot of noise and a rather foul stench. Never had anything come into the cab though. You may not want to drive that car if its doing that and find what it is.
tnrednneck
Aug 13, 2015 08:57 AM
ZsTransAm
Aug 11, 2015 07:30 PM
djmarch
Aug 9, 2015 05:27 PM
Fronzizzle
Aug 9, 2015 01:15 PM
