Will this screw anything up?
Car: 1988 Firebird
Engine: GM Performance Parts 350 HO
Axle/Gears: :(
I'm changing my car from auto to stick and I'm putting in a clutch safety switch. The switch I got came from a 4th gen and has 2 thick wires coming out of it-one yellow and one brown. I noticed that even though I had an automatic, I still had a connector for a clutch safety switch built into the harness. This connector also has 2 thick wires-one's yellow, but the other is purple. I went ahead and cut off the connector and wired the 2 yellow wires together and the purple wire to the brown. Is this what I should have done? Sorry this is so long. Any help from anyone will be greatly appreciated.
Car: Take
Engine: Your
Transmission: Pick
Brown, Purple, it doesn't matter, its just a simple open/closed switch. Sounds like you'll be OK.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
South East Thirdgen
GM Master Tech
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
'97 Bonneville SSE
RedLeader289
May 28, 2019 01:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
