Could it be VATS?
Old Sep 7, 2001 | 10:07 PM
Hulk0202's Avatar
Could it be VATS?
I've got a 91 FB w/305tbi 5-spd. I was driving it today with no problems. After shutting it down, about four hrs later I get in to go to work and it wont start. I have all power, but when I try to crank it the temp. gauge goes all the way up, but thats all it does. I noticed that if I put the key in the on position for a few seconds, without the car being started of course, the security light stayed on. When I got home from work it started right up. This happened once before, i checked the alt., that was fine, when I put the alt back on it started right up. I noticed the chip on my key seems to be flat where as I believe it used to have a raised plateau. Should the security light stay on? Any comments and tips will be greatly appreciated. Thank you.
Old Sep 8, 2001 | 03:16 AM
Omar's Avatar
The security light should go off after about 2 seconds. If it is staying on, then it is a VATS problem. Do you have a spare set of keys to use to see if the prob goes away?
1989 IROC-Z 5.7L
NOS 5151 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Sep 8, 2001 | 08:48 AM
Hulk0202's Avatar
I had my ignition cylinder replaced about two years ago and I only got one key. I figure ill buy the resistor and fix it permanantly. Thanks for the help.
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmorgetRS
Sep 28, 2015 09:33 PM
86White_T/A305
Sep 21, 2015 05:28 PM
Winchester1094
Sep 15, 2015 09:48 AM
