Lights flicker, stuff...
Old Sep 19, 2001 | 06:45 AM
shotgun's Avatar
Car: 89rs
My lights flickering at night are becoming a real problem. My lights be start to flicker, but after I've drove about ten minutes it sometimes gets real bad. Volt meeter drops to 8, redish, others its around 12 but bobbing down and up rapidly (stereo leds flicker the same when its real bad.) Only happens when the car is running...
Any ideas?
Old Sep 19, 2001 | 02:29 PM
maksik7's Avatar
I would guess your alternator is bad and when after a little bit of driving (all the battery juice runs out) it starts real bad. You should replace it ASAP because you're prolly draing the batter and might stall somewher one night.
Old Sep 19, 2001 | 03:21 PM
shotgun's Avatar
Car: 89rs
My alternator is about 8 months old, but my old one did do something funny (after I replaced the original factory alternator, a few months later the new ones plastic rings burnt and melted so I had to replace it again.) You think I should just go ahead and get another new one?
Old Sep 19, 2001 | 09:06 PM
maksik7's Avatar
You're difinetely losing power and the most likely cause is alternator failure. If you have the cash to spare go ahead and buy a new one or just wait, hopefully somebody more experienced on this board can help you out.
Old Sep 20, 2001 | 11:12 AM
mtccl's Avatar
Battery and Alternator failure go hand-in-hand. Make sure your battery will hold a charge or when you replace the alternator it will attempt to charge the battery back up and burn out the new one too. If the battery won't take a full charge....replace it too.
Old Sep 23, 2001 | 04:51 PM
CloudIROCZ28's Avatar
my lights flicker when stereo is up loud
1987 IROC-Z
G92, LB9 305 TPI, 3.23, Bright Red with Carmine Interior, Pioneer DEHP47DH CD deck.2 JBL DS645 4*6 (F).. 2 JBL DS965 6*9 (S).. New 305CI TPI ,World Torquer Heads, and soon to be Body Work
TrevinE
Sep 14, 2015 03:20 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
