how do I work this stupid thing, errr
Old Nov 26, 2001 | 10:53 PM
silentneko's Avatar
ok so I have this mutitester and some good advise now I need to figure out how to use it, someone please tell me what this stuff means:
1. its a V with a line with 3 dashes under it. its range is (200m, 2000m, 20, 200, 600)
2. its a V with a little wavy line next to it. its range is (500, 200)
3. its an A with a line and three small dashes next to it, its range is (200u, 2000u, 20m,200m)
4. its an upside down horseshoe its range is(2000k, 200k, 20k, 2000, 200)
5. its a plus sign with an arrow pointing to its center on the left side.
thanks guys
neko
'87 trans am
car in the making
angelfire.com/fl2/neko
Old Nov 26, 2001 | 11:48 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
If you're looking to test for 12v on (headlight maybe? ) wires, stick one probe wire (if it has that option) in the spot that has the V<FONT FACE="Symbol">W</FONT>, usually red around it as well, this is the +12v terminal (and also used for reading resistance or ohms)
The other probe wire plugs in the the spot that has COM by or under it along with the 3 bars that get progressivly smaller, this is ground.
Set the range (if it has one) to DCV, and, again if it has this option, set it above 12 volts. Mine has positions for 2, 20, 200, & 1000 DCV.
That should be all you need for checking for DC voltage on your car.
------------------[*]my Formula Homepage
[*]Collision P/Ns & Diagrams
"Always do sober what you said you'd do drunk. That will teach
you to keep your mouth shut."
Old Nov 27, 2001 | 07:02 AM
silentneko's Avatar
ok thanks, I got everything but which symbol is the dvc. why can't they just write the stuff out on the damn thing, errr.
neko
'87 trans am
car in the making
Old Nov 30, 2001 | 04:57 PM
86IROCZ's Avatar
1) V--- means DC voltage
2) V~ means AC voltage (the wavey line represents AC)
3) A--- Means DC Current
4) A~ Meand AC Current
The horseshoe thing means Resistance in ohms
1992rs/ss
16
Jan 28, 2016 09:58 PM
justin57
Aug 20, 2015 07:05 PM
Bob88GTA
Aug 18, 2015 03:31 PM
gta power
Aug 13, 2015 06:15 AM
milk
Aug 10, 2015 06:26 PM
