Need help quick.
Old Dec 5, 2001 | 01:25 AM
PlayBoy's Avatar
Need help quick.
If ur readin this then thanks guys.
ok i got an 85 firebird v6 swapped to v8 carb the v6 had the dash with the dummy lights witch are sooo $#$^%#$^& stupid so i got the dash from a 84 firebird with tach and all that yadda yadda. how easy to wire it in..
Old Dec 5, 2001 | 01:41 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Aside from the PITA of unplugging the speedo cable, it should just swap right out.
You will need to change the temp. 'sensor' in the drivers side head between the 1 & 3 cyl. exhaust ports & you'll need an oil pressure gauge 'sensor' to screw into the back of the block where the idiot light 'sensor' is.
A word of warning, getting to the oil press is a PITA & I don't know if the new gauge 'sensor' will just screw into the block. My 'bird has a brass 'adapter' that raises & angles it away from the intake some.
Also, be aware that the temp 'sensors' from the big name part stores read high. I'm not sure why but, they do. If you can, get the OEM temp. sensor/sender (call it what you want) out of a car w/gauges at the junkyard. If I had a p/n for an OEM one to get from the dealer, I'd give it to you & save you the trouble.
------------------[*]my Formula Homepage [*]Collision P/Ns & Diagrams
"Always do sober what you said you'd do drunk. That will teach
you to keep your mouth shut."
Old Dec 5, 2001 | 02:40 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Also, if the new cluster has a tach, you will need to run a tach wire from the coil (white wire) to the cluster.
Tim
1992 Z28, 305 TPI 5 speed, 12.0 sec @ 114.8 mph
1984 Berlinetta 305 TPI Auto, 13.8 sec @ 99.7 mph
Old Dec 6, 2001 | 02:58 AM
PlayBoy's Avatar
yeah cool thanks guys. im hoping its gonna be pretty straight forward bolt on. ill let u know how it goes
lakeffect2
Aug 23, 2015 08:44 AM
Arawn
May 14, 2002 03:54 PM
urbman
May 13, 2002 02:43 PM
Arawn
May 1, 2002 09:37 PM
john5.7 87Iroc
Nov 3, 2000 05:00 PM
