Car Door Question
Car: 1989 Iroc-z 1994 Z28 LT1
Engine: 5.7 Liter L98 Tuned Port Injection 5.7 LT1
Transmission: 700R4 and 4L60E
Car Door Question
I just recently recked my camaro and I was going to go to the junkyard to take another door off but I dont want to mess up my alarm or my power windows what do u guys suggest.?????
try and find a door with the same configuration as yours and as long as you wire up your locks the same as your old door was, you shouldn't have any problems...if you rlock mechanism in your wrecked door is not damaged you could also transfer that over to a new door
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
Find the same year door with the same options if you can, that way all the hardware will match up. The most important part to retain unharmed is the tumbler lock, because you can no longer get ones from GM that will match the key you have.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
