factory tach question.
Old Jun 6, 2003 | 05:44 PM
jon_volk's Avatar
i know the factory tach isnt very accurate in its reading but are they consistently inaccurate? as in if the factory tach reads 1000rpm more or less at say 5000rpm does it always read the same at that rpm? I dont really want to install an aftermarket tach for a sleeper look.
Old Jun 6, 2003 | 11:57 PM
25THRSS's Avatar
It depends on the car, but I don't believe 1,000 rpm is normal. I would say more like a couple hundred.
Old Jun 7, 2003 | 07:42 AM
jon_volk's Avatar
i was just using that as an example. i dont know how much my tach is off by but i want to know if these tachs are off by the same amount every time.
Old Jun 7, 2003 | 11:52 AM
25THRSS's Avatar
no, it varies from car to car.
Old Jun 7, 2003 | 12:16 PM
jon_volk's Avatar
no offense but lets try this again......
in any given car....will the tach be off by the same amount every time you rev the engine in THAT car? get what im saying? i knwo all cars are diff and know that all the variations will be diff but in the same car with the variation be the same every time you accelerate through the gears?
Old Jun 7, 2003 | 12:19 PM
25THRSS's Avatar
The further you rev the engine the further the tach will be off.
Old Jun 7, 2003 | 12:28 PM
jon_volk's Avatar
lets simplify this some more..... the only thing i really care about is the only rpm reading that matters redline/racing shift point (whichever comes first) Will the tach be off the same amount at the engines redline everytime i bring it to redline? what i want to know is will the facotry tach give a repeatable redline rpm even though the displayed RPM is different from the actual.
Old Jun 9, 2003 | 12:59 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
heres how to do what you're asking.
take a scan tool, one that shows RPM.. i used winALDL..
rev the car so that the SCAN TOOL reads your redline RPM.... then look at what the tach reads...
the tach is inaccurate but what is shows is repeatable... it doesnt change everytime you rev it.
Old Jun 9, 2003 | 01:05 PM
25THRSS's Avatar
how much is yours off by?
Old Jun 9, 2003 | 01:06 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
at a real engine speed of 5k it reads 6130 at idle its off by 300.
i have a 91 so its the newer style one.... btw my tach really sucks for some reason... most tachs arnt off that much.
Old Jun 9, 2003 | 01:08 PM
25THRSS's Avatar
damn man, that's a lot!
Old Jun 10, 2003 | 08:42 PM
Dragons91RS's Avatar
Car: 91 Camaro RS
Engine: 305 LO3
Transmission: 700-R4
Ha I got ya beat. my stock tach is off by 1000 rpm's at idle, and gets worse the higher up you go. when I actualy rev to 4000 rpm's(aftermarket tach installed) my stock tack pegs past 7000 rpm lol
IMOP it is best to get an aftermarket tach put in.
since I installed my new tach my stock tach has recently started to read about 200rpms higher at all times, and my new tach still reads the same as when installed. so what ever makes the stock tach read so poorly can apparently get worse.
gta892000
Sep 16, 2015 12:40 AM
gta892000
Sep 16, 2015 12:37 AM
TrevinE
Sep 14, 2015 03:20 PM
Ironhead38
Sep 7, 2015 02:26 PM
Ian Irvine
Sep 4, 2015 08:08 AM
