Check Engine Light
Old Jun 10, 2003 | 12:28 PM
warrior_91's Avatar
Car: 86 T/A
Transmission: 700-R4 Auto
Check Engine Light
Hi, the other day, my check engine light came on while I was driving. So everytime I go to drive my car, it stays on. I tried to use my diagnostic feature under my dash, but nothing works. I put a jumper wire to the A & B terminals to see if any codes will flash but the light just stays on. It won't flash at all. Whats the problem? Im guessing something is wrong with the diagnostic system or something because it aint working at all. If the diagnostic system aint working, how would I go about fixing it?
86 Trans Am
Old Jun 11, 2003 | 09:40 PM
CamaroRS91x's Avatar
Does it come on immediately when you start up your engine? Also, I'm not sure if you're using the paperclip method...but goto WalMart and they have SES decoders for like 20 bucks. Ps. Where in michigan are you
Old Jun 13, 2003 | 09:42 AM
warrior_91's Avatar
Car: 86 T/A
Yes, it turns on when I start the engine up. I tried resetting but still the light stays on when I try to troubleshoot it. Nothing will flash. I live in Port Huron, MI.
Old Jun 13, 2003 | 11:30 AM
Vader's Avatar
Did you check to see if the SES lamp flashes once briefly when you first turn on the ignition?
Old Oct 8, 2010 | 03:19 PM
SDZ28's Avatar
Car: 1982 Z28
Re: Check Engine Light
I know this is a really old thread, but I'm having some problems with my check engine light also.. it's on whenever the car is running and turns off when I shut the car off, but when I ground the terminals with a paperclip it doesn't give me any codes. Like Vader was mentioning, it flashes once briefly when I turn the ignition on, but it never flashes the code 12 or anything else either. What would cause that to happen?
Old Oct 11, 2010 | 12:06 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
SES Mess
Make sure the key is OFF.
Disconnect the ECM.
Turn the key to RUN.
Does the
SES still illuminate with the key in RUN?
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Old Oct 11, 2010 | 05:39 PM
SDZ28's Avatar
Car: 1982 Z28
With the ECM disconnected, the SES light came on and stayed on when I turned the key to run. After plugging the ECM back in, I turned the key back to run and it still is only giving one brief flash. According to my Haynes manual, its supposed to give a code 12, which is basically 3 flashes, if the diagnostic system is working. Any ideas about what else I should check?
Old Oct 12, 2010 | 01:26 PM
NINÅ's Avatar
Transmission: 765R4
SES Mess
Because the Service Engine Soon light stays on with the ECM disconnected try this: With the ECM disconnected, and the GAGES fuse removed, does the Service Engine Soon light still stay on with the key in the RUN position?
Happy Racing!
How bout those too scared to drive without headlights in the daytime and the ones that need headlights for a little rain
Old Oct 26, 2010 | 11:47 AM
SDZ28's Avatar
Car: 1982 Z28
With the fuse removed, the light shuts off..
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
