Three tach wire questions...
Old Nov 11, 2003 | 04:46 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
1) Is the tach wire the smaller-gage, white wire on the coil?
2) Does the wire go to the instrument cluster tach only or is it involved in any other electrical function?
Background - My tach is bouncing around above 3K rpms. When the car is floored, the tach goes to zero always. I have a monster tach ready to go in, so I'd like to simply disconnect the factory tach wire at the coil since it may be shorting somewhere. Then I would just run a new wire from the coil through the firewall and into the cab.
3) Any problems with doing this?
Old Nov 11, 2003 | 09:33 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
use the small white wire that is off the coil that is coming out of the harness, if you look, 2 wires(in 1 plug) off the coil go to the dist., and 2 go in to the harness, use the one that goes in top the harness, all it goes to is the tach, the ECM gets the RPM from a different source
Old Nov 11, 2003 | 10:10 PM
JMatlock88's Avatar
Car: 1991 Formula
That's what I was wondering. Thanks!!:hail:
eightsixseven
Dec 16, 2024 01:50 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
stalkier
Aug 7, 2015 04:49 AM
