timing problems
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
timing problems
is there anyway to easily check the knock sensor? does the engine still run well if it is disconnected? i'm having trouble with my timing....the ecm isn't advancing the timing enough from 2000 to 4000....the car just stops accelerating in 3rd at about 3000. it seems to hit a wall.....or is it possibly the ignition coil?
Ghettobird52
Jul 5, 2024 11:18 PM
db057
Aug 11, 2015 10:11 PM
