need help figuring out where wires go
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
well guys after looking at the ghetto wiring job my car came with i'm gonna fix it. now heres the problem i have a few wires that i have no clue where they go or what they are for, anyone have any ideas i'd appreciate it
heres a pic of the are of the engine they are in
Car: 1989 Camaro
Engine: 383
That looks like wires or the AC. The two in your hand goes on the AC compresser( 1 to the clutch, 1 one the back to a pressure switch) the one by the coolant overflow should go to a hight pressure switch on the AC line
Car: 1989 Camaro
Engine: 383
Did it come from GM without AC? If so they may use the same harness either way. You can tuck them away in the harness and make the engine compartment look cleaner or remove them if your not ever gonna install AC
Car: 1989 Camaro
Engine: 383
I have a 90 RS 3.1 I bought from a guy down the road after he knocked a hole in the oil pan and locked it up. I looked at it and those connectors look the same as what you have and are in the same place. I'd just tuck them away myself, I'm not one to go cutting up a wiring harness.
litemupp
Southern California Area
Aug 23, 2015 10:09 PM
db057
Aug 11, 2015 10:11 PM
