kill switch?
Old Mar 25, 2004 | 12:01 PM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
Transmission: T-56 LT1
kill switch?
wheres the best place to wire in a kill switch? I'm taking it one of those many wires that feed into the steering colum and eventually get to the key tumbler...?
cheers
Blake
Old Mar 25, 2004 | 03:13 PM
tyty49's Avatar
Car: 91 Maro & 97 Ram & 05 Roadstar
You can do a search on this, there were a ton of great ideas, just a little while back.
BTW, I used the thick yellow one out of the base of the collum.
Old Mar 27, 2004 | 07:38 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
isnt the thick yellow wire under the steering column the airbag wire?
Old Mar 28, 2004 | 08:42 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Hmm that gives me an idea. Air bag in the face would be a good theft deterant.
Old Mar 28, 2004 | 11:15 AM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
also perfect for a lawsuit, the wires on the steering colmn that are hooked to the ignition "SWITCH", switch, not lock cylinder, are high amperage wires, if u go and wire some dinky toggle switch to one of those it is liable to get very hot or start a fire, some places u can hook one up to are the clutch switch wires(if manual) or the neutral safety switch wires(auto), coil power,or you could always do it to the VATS wires if so equipped, but that might change the reistance, not sure that would be a good idea
Veaceonee
Sep 29, 2016 08:15 PM
tglennon11
Sep 23, 2015 05:30 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
Randomtask2
Sep 10, 2015 08:37 AM
luvofjah
Sep 3, 2015 07:08 PM
