alternator / charging system trouble
Old Apr 16, 2004 | 02:23 AM
luvs2play's Avatar
Hi I recently got a 1985 camaro z28 with a 5.0 305. The battery was not charging so I replaced the alternator and battery (the battery looked very old anyways) but now the new alternator isnt charging either.
On the rear of the alternator is a small harness with two wires coming out. One is connected (i believe it is red) to the back of the alternator and the other is just hanging (black)...
Was wondering if the wire not being connected is what is keeping my system from charging or if I need to look elsewhere for a problem (the wire doesnt appear to have a mate...no other loose wires it would match up with)
any help would be appreciated
Old Apr 16, 2004 | 03:13 PM
luvs2play's Avatar
please help as I have now had both the battery and the alternator retested...as well as replacing the worn wiring harness. Any other things that could cause the charging system not to charge?
Old Apr 17, 2004 | 10:16 PM
red90bird's Avatar
Car: 1990 Firebird
Engine: LS3
what kind of alt
what style of alternator do you have? is there just a red wire or is there a wiring harness to go with it? also do you have the right size pully on it? is the belt tight? thats just a couple of things I would check, ohh is the alt big enough?
Old Apr 18, 2004 | 12:47 AM
luvs2play's Avatar
yes it is the right size...belt tension is correct...it has the small harness with 2 wires ...
any ideas on what else it might be?
Old Apr 18, 2004 | 07:02 AM
Cruz'N Bruz'R's Avatar
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
You need both wires connected.
Old Apr 18, 2004 | 07:09 AM
JamFitz's Avatar
Car: '89 FB TA GTA
Engine: ZZ4 tpi
Transmission: 3.27 auto: stock gear box
Axle/Gears: Stock
Is the 20A fan fuse in? We took this out to stop the battery running flat when waiting to turn on the car, and then found out once it was too late that this disables the alternator.
JAmes
Old Apr 18, 2004 | 07:12 AM
JamFitz's Avatar
Car: '89 FB TA GTA
Engine: ZZ4 tpi
Axle/Gears: Stock
Is the 20A fan fuse in? We took this out to save power when the car wasnt started, then ran the car, and found out all too late that this fuse disables the charging system.
JAmes
Old Apr 18, 2004 | 07:49 AM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
edit
Old Apr 18, 2004 | 08:33 PM
luvs2play's Avatar
any idea where the second wire would be found ... the red is going to the battery...the other has no obvious mate ...or unobvious for that matter. How would I test?
Ill check on the 20 amp fuse
Old Apr 19, 2004 | 01:20 AM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
That is the Field Sesing Wire it tells the Alt to start charging. On my car it connects to a Brown wire in the Body harness (the one that enters the car on the drivers side ofthe firewall.) I will look at my Chiltons Manual and find out what color it is for a 1985.
Old Apr 19, 2004 | 01:50 PM
luvs2play's Avatar
hey thanks for checking!
Old Apr 21, 2004 | 05:05 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
I can't find my chiltons manuall. I will keep looking.
Sorry it is taking so long
Old Apr 22, 2004 | 04:11 AM
luvs2play's Avatar
no problem man...any help is always good help (no matter how long it takes)
Hotrodboba400
Dec 10, 2019 07:07 PM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
scottmoyer
Sep 7, 2015 07:06 PM
Slush92RS
Sep 2, 2015 08:56 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
