CD ignition test
Old Jul 21, 2004 | 08:22 AM
Breazlan's Avatar
Car: 88 Firebird
Engine: 302 SBC
Axle/Gears: 4.27 Dana 44
CD ignition test
Is there a way to test a cd box with a multimeter?
Old Jul 21, 2004 | 11:45 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Not really.
Old Jul 21, 2004 | 12:16 PM
Breazlan's Avatar
Car: 88 Firebird
Engine: 302 SBC
crap
I have one I want to sell. People want to know if it works obviously, I don't know how to test it. I never hooked one up either. Is there anyway to test one? Installing is one way if I knew how.
Old Jul 21, 2004 | 01:36 PM
LaxStreetRacer's Avatar
Car: 91 Z28
alright check your documentation (should either be in the manual for it, or some brands a sticker right on the chassis of the deck) Take the constant and switched power(should be red and yellow more than likely) and touch them to the possitive terminal of a cars battery, Obviously ground the ground(black), then hit the power button... You can do this just to verify it works but you would have to have a speaker hooked up to it if you need to verify output. Also make sure all the loose wires in your harness arent touching if you decide to do this.
Anyways hope this helps, and by cd box hope you are talkin about your head unit (no way to test with voltmeter).
Old Jul 21, 2004 | 02:01 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
He's talking about a Capacitive Discharge ignition box, like an MSD, not a Compact Disc player.
Old Jul 21, 2004 | 02:04 PM
Breazlan's Avatar
Car: 88 Firebird
Engine: 302 SBC
multiple spark capacitive discharge ignition
Old Jul 21, 2004 | 02:24 PM
Car: 91 Z28
LMAO
Old Jul 21, 2004 | 03:01 PM
goofnrox's Avatar
If its an MSD box its easy to test.
Hook it up top power with a coil, and touch the white wire to ground, should spark.
http://www.msdignition.com/1troub1.htm
Old Jul 21, 2004 | 03:53 PM
Breazlan's Avatar
Car: 88 Firebird
Engine: 302 SBC
It is a mallory, it has 8 wires coming out of it. One hole has black, red, green and yellow coming out and the other has a black, red and two lighter gauge wires that are black and green.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
Johnoooooo
Sep 22, 2015 08:55 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
