Wiring Up my Lighted Dice to...
Old Aug 13, 2004 | 01:08 PM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
... come on when the brake lights go on? They're red so I just think it'd be cool. Right now my dice are just wired through a switch which gets power from a "BATT" terminal in the fuse box. How could I go about doing this?
I'd like to keep it so that I have the same functionality as now, where I can flip the switch and leave them on when the car is parked. Maybe a 3 way toggle switch?
Old Aug 13, 2004 | 06:51 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
The easiest way would be to power it from two places. One power would come from the brake switch and the other one you already have in place. So all you really have to do is wire in a power wire from the brake switch.
Old Aug 14, 2004 | 02:06 AM
89V6FBIRD's Avatar
Does the famous Trickster have a wiring diagram for the switch? :hail:
Old Aug 14, 2004 | 08:07 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
While I don't have the exact wiring diagram for the 89 firebird handy, I do have the diagram for an 89 camaro which should be similar enough for you to get the general idea. I have also included the diagram for the third brake light since it operates off a seperate circuit in the brake switch. I thought I would get this to you before Charley starts knocking on the door.
Old Aug 14, 2004 | 08:08 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
page 2
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
page 3
Old Aug 14, 2004 | 04:32 PM
DVL86's Avatar
Car: 85 Iroc-z
Engine: 5.0 V-8
Trickster, where do you pick up these schematics? THANKS!
Old Aug 14, 2004 | 04:38 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Handy Dandy GM service manuals for the various years.
Old Aug 14, 2004 | 04:40 PM
DVL86's Avatar
Car: 85 Iroc-z
Engine: 5.0 V-8
Ah, yes. That would explain it completely. How do I go about picking up a manual for an 85 iroc?
Old Aug 14, 2004 | 04:41 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
There's one slight issue with just powering it from 2 places. If you pull a wire from a switch and another from the brakelight switch and tie them together at the dice, then the brakelights will come on anytime you turn on the switch. Something tells me the local cops might not like that too much.
You need to use a 3-terminal switch. Wire the middle terminal to the dice, one end to the brakelight switch (I'd use the 3rd brakelight wire personally, so that if there's a problem it won't interfere with the regular brakelights,) and the other end to the fusebox terminal you're using now. My
Old Aug 14, 2004 | 04:50 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
There are about 3 on e-bay right now that should be ending the auction within the next couple of days. Just keep watching them and you might get one for a good price. I got mine for $15.00 + $4.50 shipping.
Old Aug 15, 2004 | 03:22 PM
dankhound's Avatar
Car: 91 RS
Hmm didnt think about that brake light issure. You could also use a diode to prevent power from the dice circuit entering the brake light circuit.
Old Aug 15, 2004 | 11:52 PM
89V6FBIRD's Avatar
That's what I figured, an ON-OFF-ON type switch, where the First ON would be wired the same way I have now, the 2nd ON would be tied into the brake circuit.
Thanks for the Diagrams Trickster!
Old Sep 3, 2004 | 10:57 AM
89V6FBIRD's Avatar
Finally getting around to doing this... I'm not sure what you guys were talking about w/ the diode. But from the 3rd brake light diagram, I'm gonna splice into the YELLOW wire coming off the switch and wire that to one of the ON positions on my switch. (ON-OFF-ON) The first ON is constant while the second ON is from the brake switch. The dice have their own ground. Do I have this right?
Old Sep 3, 2004 | 01:04 PM
TheGreatJ's Avatar
Yep.
Old Sep 3, 2004 | 08:52 PM
dankhound's Avatar
Car: 91 RS
A diode is just a one way check valve for electricity. Avalable at any radio shack. It would have allowed the use of a single pole single throw switch with out getting the feedback into brake light circuit. The way you have it wired up is perfect thou so a diode isnt necessary at this point.
Old Sep 4, 2004 | 07:57 PM
Mirthman's Avatar
Car: 1988 GTA Trans Am
Engine: pos 305
Transmission: 700r-4
what if you used a relay? a single pole double throw relay. connect terminal 30 to the dice, terminal 87a to the brake lights, 87 to a 12 volt source. terminal 85 and 86 are the coil, one goes to a switched 12 volt source the other ground. so to have the dice light with the brake lights turn switch off. to have them light when you want them to turn the switch on. if ya need any further explanation drop me a line. hope this helps.
TheJoeY88
Dec 31, 2016 07:30 PM
Jae992
Aug 27, 2015 09:07 AM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
