my windsheild water doesnt work
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
hey guys.well i have a lil problem with my windsheild water system.it doesnt want to shoot water out no more,but theres like no power going to the plug u connect to the lil pump.wat can this be?i connect the lil motor to the battery and it spins,also if u push the switch inside like if u wanted to shoot water the wipers move but no water. wat can this be?
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
did you check the fuses already ?
its possible that the switch for the turnsignals / wipers is bad or has a wire cut or loose going from it
Car: 89 Camaro RS
Engine: 5.0 tbi
my turn signals cruise control and wipers all work fine.my car use to shoot water before then one morning it stop shotting wat can it be
if the pump works and there arent any blown fuses then id say the switch ......im not sure but there may be a relay somewhere hmmm....let me get trickster to see about this
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Okay, the switch is located inside the steering column and the multifunction lever fits into it. The connector for it is located on the right side of the steering column towards the base. There will be two connectors there but you want the one towards the base of the column. I am including a schematic of the wiper system as well as a test for the switch itself. The wire on the switch is the pink wire. Follow the test and check that wire at all connection points from the switch to the connection on the steering column to pin "C7" of connector C100 on the firewall bulkhead to pin "F" of connector "C1" on the wiper motor module then check pin "D" (red wire) of that same connector from the backside with the connector connected, next check the red wire at the washer motor pump. If at any point in these checks you fail to have power with the ignition "ON" and the washer switch "ON", you have found your problem.
Car: 89 Camaro RS
Engine: 5.0 tbi
well that will help me out a bit, but to see inside the coulumn dont have to remove the stering wheel and all that other junk?
Car: 1989 Formula 350
Engine: Stealth Rammed 350
Axle/Gears: 3.45 9 bolt
OK i got a similar problem. with mine i can hear the washer motor going but nothing comes out. i tried blowing the lines out with an air gun and some crap came out but it still isnt picking up any fluid. its also not leaking out anywhere. its just not sucking at all.
sorry i couldnt help myself .....lol..it sounds as if there is something plugging it up where the pump draws in at do as trickster said and remove and clean the pickup for the pump
Car: 1989 Iroc-Z
Engine: 5.7L TPI
No, the switch itself is inside the steering column. The connector that you want to test is on the right side of the steering column under the dash as I have mentioned at least three times in this thread already counting this one. It is easily accessable although being a contortionist doesn't hurt either. For those of you who aren't contortionist's, feel free to remove the drivers seat.
Car: 89 Camaro RS
Engine: 5.0 tbi
ohh okay i check it out some time later so under the dash cover look for the plug on the right side okay go t itand if there is no signal?
evilstuie
Jan 9, 2020 08:29 PM
Street Lethal
Aug 12, 2015 11:33 AM
