code 14/15
Old Oct 17, 2004 | 05:09 AM
cyipher's Avatar
Car: 1984 Pontiac Trans Am
Engine: 305 SBC
Transmission: Automatic
code 14/15
I know it pertains to the temp sender on the intake manifold elbow, i have checked the connection an even replaced the connection from another wiring harness, and swapped the sender from another engine, and i'm still getting this light, any help would be great.
Old Oct 17, 2004 | 07:15 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Did you remember to clear the codes from the computer by disconnecting the battery after doing these things. If you did and still get these codes its time to do some trouble shooting. If you didn't clear the codes, then you are probably just seeing the old codes. In your title you say code 14/15, does this mean that you are getting both of these codes at the same time? 14 is for low voltage and 15 is for high voltage on the circuit.
Old Oct 17, 2004 | 11:41 AM
cyipher's Avatar
Engine: 305 SBC
well i had a code 15, i switched the connector and the sender, now i got a code 14.
Old Oct 17, 2004 | 07:51 PM
cyipher's Avatar
Engine: 305 SBC
never mind, i got it fixed
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
