Replacing Ignition Switch
Old Nov 5, 2004 | 02:22 PM
tamonez's Avatar
Car: 88 Iroc
Transmission: 5 speed
I've been having the problem most people have with the car not starting, It did it once last week and came right back on but now it doesnt do anything. I dont have VATS or the starter enable relay. So I dropped the steering colum and when I turn the key I noticed a rod sliding along the top of the column. So then thanks to when my car was stolen, the side of the steering column was exposed I pulled the rod from there and the car starts right up.
In short I figured the problem is with the ignition switch. And the same A-hole that stole my car took my repair manual (I guess he must a been a camaro owner) I dont know where to start. So if anyone has instructions on changing the switch, It'll be greatly appreciated.
Terrence
Old Nov 5, 2004 | 04:03 PM
Morley's Avatar
If it will start when you pull on the rod you don't need to replace the switch, just adjust it Find the switch and loosen the screws on it and slide it to adjust.
Old Nov 5, 2004 | 04:17 PM
tamonez's Avatar
Car: 88 Iroc
Thanks so much I'll try that.
Old Nov 5, 2004 | 09:57 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If you will do a of the board you might find the diagram and instruction for adjusting he ignition switch that I posted recently. If you can't, let me know and I will get the info to you.
Old Nov 6, 2004 | 11:17 AM
tamonez's Avatar
Car: 88 Iroc
Thank alot guys worked like a charm. It was actually easy once I got the high beam switch off. I may have done too much adjusting, because now I cant turn the key back once and get the radio to come on.
Now I may just replace the switch since its only 10 bucks and if it started to fail then thats its probably ready to go.
Thanks alot guys, these boards are always helpful!
Terrence
BRoss99
Aug 10, 2025 05:08 PM
89GTAOz
May 16, 2020 09:31 AM
Bryan F
Aug 18, 2015 02:28 PM
djmarch
Aug 9, 2015 05:27 PM
Fronzizzle
Aug 9, 2015 01:15 PM
