a Sticky for switch/circuit install?
Old Jun 15, 2005 | 09:09 AM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
Could anyone take the time to make a sticky with pictures for installing a switch/circuit from the battery to some area in the car, using the proper electical equipment so people (amatures) can get a grasp on how to do it? It would be nice to see the proper way to run and connect wires...
Old Jun 15, 2005 | 09:18 AM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
im at work now, but i could draw a nice schematic thats fairly easy to read and email it, post here or fax it when i get off??
Old Jun 15, 2005 | 10:30 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
"Proper equipment" depends on what the circuit is for.
Old Jun 15, 2005 | 03:45 PM
black89ws6's Avatar
Car: 89 Formula, WS6
Engine: LB9/peanut cam :(
Do you mean like this:
First and foremost suggestion I would make is to only tie in to the battery directly if it is actually necessary. Really, unless you have a high load accessory, like a big stereo amp, or a power inverter, it's not necessary. It's better to tie in to your electrical system away from the battery. Most of our cars have a positive junction block only a foot away from the battery. That junction block, the post on the back of the alternator, and the starter solenoid are all places you can tap iinto power with less likelyhood of corrosion affecting your electrical junction.
Connections made on the battery will be prone to the corrosion shown in the above photo (unless you have an optima).
Old Jun 17, 2005 | 09:14 PM
Car: 1988 SC Camaro
Engine: 305 TBI
thanks...I like that pic of the battery terminals, thats funny
Old Jun 17, 2005 | 09:28 PM
black89ws6's Avatar
What kind of electrical device are you wanting to install?
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
86IROC112
Aug 17, 2015 07:57 PM
