speed unlimited mod question
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
Axle/Gears: strange 12 bolt 3.73's
ok im about to splice a switch into my vss wire that goes into the ecm. i have no problem wiring it up but my question is will my speedometer stop working?
thanks
ryan
thanks
ryan
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: speed unlimited mod question
Originally posted by 92camarors5spd
im about to splice a switch into my vss wire that goes into the ecm.... will my speedometer stop working?
Engine: TPI 305/ v6
Originally posted by Trickster
Not to mention that his cruise control will also cease to function (if it worked in the first place).
Where's my memo ?
heh
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Originally posted by deadbird
Woah, woah... woah! These cars are suppsed to have working cruise units ??
Where's my memo ?
heh
Where's my memo ?
heh
Engine: TPI 305/ v6
I think you put it in the litter box for the hamster that you have in the engine bay for your turbo set-up .
