pwr wndws
Car: 91 camaro rs
Engine: 305 tbi
Transmission: 5 spd
Axle/Gears: what ever stock is
pwr wndws
ok, so i replaced the motor in the right side. and the window is still slow. the left one is much faster. does anyone have any secrets or something to speed these things up?
Car: 1989 Firebird Formula
Engine: 305 T.B.I. (Vin tag "E" = LO3)
Transmission: THM-700-R4
Axle/Gears: 10 bolt posi 3.23
well ive got a couple of pointers
1) lube the tracks for the window
2) there a moduel for the windows which is located under the drivers side kick panel and may be slightly under the carpet. this thing should be coverd with black goo... i read something from a previous post and i think if u replace that you windows will go faster... srry im kinda foggy with that one since trickster posted on that a while back...
Car: '85 Trans Am
Engine: 350 Crate Motor
Axle/Gears: 3.27 posi
I recently replaced the switch in my console since it was partially broken and wouldn't work now and then. The window was also slow, but since I replaced the switch, it goes just as fast as my other window. I didn't expect this and thought that I would have to relace the motor but I gues I got lucky. try switching the switches in your console and see what happens. If not, I've heard something about a regulator going bad before.
Car: 91 camaro rs
Engine: 305 tbi
Transmission: 5 spd
