Marker Short
Old Mar 5, 2006 | 02:39 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
Marker Short
I have a short with my front driver side marker light . When the lights are off the turn signal light works . When lights are on the light on the dash stays on , but the Marker dose not (but the turn signal works).I just replaced all lights , cleaned the sockets and replaced the flasher . Befor I replaced the flasher I would blow the 20 amp tail fuse . Now I it dose not blow . I also followed the wires back to the out side of the fire wall and it has no brakes . I also tighend the 2 reverse torx bolts in the tilt colum a while back , maybe its grounding out in thier but went back together well . Any other places I can look first .
skinny z
Oct 5, 2015 06:23 PM
lewandom
Oct 1, 2015 08:15 AM
