TPS sensor
Old Mar 26, 2006 | 02:07 PM
badCHEVELLEman's Avatar
Car: chevelle + camaro
Engine: 520hp 350 350
Transmission: th 350 700r4
Axle/Gears: 4:56 3:23
TPS sensor
i've heard of adjusting your throttle position sensor "tps'
is this true?!?! how would you go about to do it
91 Z-28 tpi 5.7
thanks
eRiC
Old Mar 26, 2006 | 04:37 PM
Jza's Avatar
Jza
Some can, and some can't. If you have a speed-density system like TBI or late-3rdgen TPI, then you can't.
If it's adjustable, you measure the voltage on the blue wire, loosen the two torx screws on the TPS sensor, and adjust it (by turning the whole sensor) until the voltage reads .45V.
You can tell just by looking whether or not it's adjustable. The holes in the sensor will be slotted instead of round holes.
Also, you do this at the same time you set the idle-air speed and the timing, as they all effect the idle speed.
db057
Jan 10, 2020 08:55 PM
92firebirdguy
Sep 1, 2016 07:53 AM
bbsr72
Apr 2, 2016 09:12 AM
Fred SS
Oct 12, 2015 11:27 AM
BWilcox
Sep 20, 2015 12:19 PM
