Codes?????
Old Mar 31, 2006 | 05:55 PM
Johns1989irocz's Avatar
Car: 1989 Iroc
Engine: 5.7L 350 TPI
Codes?????
My check engine light comes on and goes off at various times and rps and throttle, I jumped my aldl to pull the codes and after the 12 flashes 3 times, the light has a flash pause flash and then a different code starts, 3 flashes with no pause, can anybody tell me what they are??
1989 Iroc
350 tpi
all I know is one of the previous owners rebuilt the top half of the engine, and had the heads shaved.
any help would be great.
btw, sometimes when the light comes on, even when i am on the throttle, the engine cuts out, and then I have to let off the gas and then hit the gas and it clears up, but the C.E.L. remains on for a few seconds.
I just bought the car last week and want to tear up the roads, but not with the light coming and going
Old Mar 31, 2006 | 10:06 PM
Code's Avatar
Car: 1989 Black Pontiac Firebird
Engine: 2.8l V6
Transmission: Automatic
Axle/Gears: Stock Crap
http://www.iroczone.com/specs/TroubleCodes.htm
THE CONNECTOR
| 1 2 3 4 5 6 |
| 7 8 9 10 11 12 |
DISPLAYING THE TROUBLE CODES
Run a wire/hairpin from Pin 6 to Pin 12 with the ignition off (although on later cars it should be from Pin 5 to Pin 6), then turning the ignition to the on position without starting the engine will flash the "Service Engine Soon" light in the following sequence: flash, pause, flash-flash, long pause flash, pause, flash-flash, long pause flash, pause, flash-flash, long pause Following this "12" code repeating three times will come any trouble codes stored, flashing each of them three times. If you do not see the "12" flash three times, your diagnostic circuit is defective.
Some vehicles will display stored trouble codes, then "12" again, followed by energizing "most system controlled relays." The fuel pump relay will not energize. The idle air control valve will fully extend to enable checking minimum idle speed.
CLEARING THE TROUBLE CODES
Turn the keyswitch to the off position. To clear any trouble codes, disconnect the power feed for 30 seconds. If this is done at the battery, and your car stereo is equipped and programmed with a four digit pin code, you may have to re-enter that as well to use your stereo again. A better place to remove power is at the fuse.
TROUBLE CODES
12. No reference pulses to Electronic Control Module (ECM).
13. Oxygen sensor signal stays lean during warm engine cruise
14. High temperature indicated at engine coolant temp. sensor
15. Low temperature indicated at engine coolant temp. sensor
16. High battery voltage OR
Direct inition system open or shorted to ground
17. RPM signal problem
18-20. N/A
21. High voltage at throttle positon sensor
22. Low voltage at throttle positon sensor OR
Fuel cutoff relay circuit open or shorted to ground
23. Low temperature at manifold air temperature sensor OR
Throttle position sensor error
24. Circuit fault in vehicle speed sensor
25. High temperature at manifold air temperature sensor OR
Vacuum switching valve circuit open or shorted to ground OR
High voltage at ATS sensor
26. Fault in quad driver module
27. Fault in 2nd gear switch
28. Fault in 3rd gear switch
29. Fault in 4th gear switch
30. N/A
31. Low voltage at manifold absolute pressure sensor OR
Fuel injector OR
Park or neutral switch OR
CAM diagnostic OR
Governor malfunction OR
Wastegate overboost OR
Wastegate eletrical signal open or shorted to ground
32. Fault in barometric pressure sensor circuit OR
Fault in exhaust gas recirculation valve diagnostic switch OR
Fault in electronic vacuum regulator valve
33. High voltage (low vacuum) at mass air flow sensor (or MAP sensor)
34. Low voltage (high vacuum) at mass air flow sensor (or MAP sensor)
35. Idle speed can not be set to desired RPM
36. Burn off at mass air flow sensor OR
Problem in transmission shift OR
Fault in direct ignition system OR
Missing pulses in electronic spark timing signal
37. N/A
38. Fault in torque converter clutch brake switch
39. Fault in torque converter clutch circuit
40. N/A
41. Fault at cam sensor OR
Cylinder select error OR
Tach input error
42. Fault at electronic spark timing circuit OR
Fault at direct ignition system OR
Fault at fuel cutoff relay circuit
43. Low voltage at electronic spark timing circuit
44. Oxygen sensor lean
45. Oxygen sensor rich
46. Fault at vehicle anti-theft sytem OR
Fault at power steering switch
47. Problem at Electronic Control Module (ECM)
48. Misfire
49. Vacuum leak
50. N/A
51. PROM error
52. Problem at Electronic Control Module (ECM) -
Missing fuel calpac missing OR
Analog to digital converter error OR
Fault at quad driver module OR
Low voltage at oil temperature sensor
53. High voltage at battery OR
High voltage at exhaust gas recirculation valve OR
Voltage reference error OR
Problem at vehicle anti-theft system
54. Low voltage at fuel pump OR
Low voltage at Fuel pump relay OR
Output failure at quad driver module
55. Problem at Electronic Control Module (ECM) -
ECM failure OR
Serial bus error OR
Fuel lean malfunction
56. Low coolant or corrosivity OR
Fault in port throttle system vacuum sensor
57. N/A
58. Problem at vehicle anti-theft system
59-60. N/A
61. Oxygen sensor degraded OR
Port throttle system error OR
Cruise control problems
62. Gear switch input diagnostics OR
High voltage at oil temperature sensor OR
Fault in cruise control- vacuum solenoid circuit
63. High voltage at manifold absolute pressure sensor OR
Fault in exhaust gas recirculation valve OR
Fault at right oxygen sensor
64. Low voltage at manifold absolute pressure sensor OR
Right oxygen sensor lean
65. Failure at exhaust gas recirculation valve OR
Faulure at injector peak/hold diagnostic OR
Right oxygen sensor rich OR
Fault at cruise control position sensor
66. Internal reset of Electronic Control Module (ECM)
67. Fault at cruise control switch
68. Fault at cruise control switch
69. Fault at air conditioner pressure switch
70-87. N/A
88. Internal reset of Electronic Control Module (ECM)
Old Apr 1, 2006 | 10:31 AM
Car: 1989 Iroc
I just need to know what the codes i posted are,
flash pause flash is this 11 or 22
flash flash flash what would that be?????
Old Apr 1, 2006 | 11:08 AM
Code's Avatar
Engine: 2.8l V6
Ide try clearing them, then see if it happens again. SORRY I posed all that. Silly me was trying to help.
Old Apr 1, 2006 | 02:34 PM
Car: 1989 Iroc
thats cool man, i appreciate your help
Old Apr 1, 2006 | 04:02 PM
Jza's Avatar
Jza
It's easier to just pull the ECM fuse by the battery.
12 is the lowest code, so you're either misreading it or something way off.
Almost sounds like you're describing "23" there.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
