ignition problems
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
ignition problems
i replaced the starter on my car and while i was at it i tore the intake off to fix the leak it had in the rear, i put everything back together accept dropping in the distributor, i go to crank the motor so i can get he #1 cyl at TDC, and nothing happens, then after holding the key on for about 3 seconds a relay starts buzzing under the dash and then one under the hood on the drivers side, what does this mean?? Is it no good? i m not quite sure what went wrong, it seems like i have no ignition power at all, anyone know whats goin on? thanks
Brandon
Brandon
