IAT sensor question
Old May 15, 2006 | 09:16 PM
CamaroKid89RS's Avatar
Car: 89 Camaro RS/SS
Axle/Gears: 10 bolt with 3.42
IAT sensor question
I am trying to use my tpi air cleaner setup for my LT1. My question is would a tpi iat sensor work in place of an lt1 iat sensor?
Old May 18, 2006 | 11:24 AM
Noone knows?
Old May 18, 2006 | 11:55 AM
Firebat's Avatar
Doesn't look like the TPI IAT/MAT will work as a direct replacement for the LT1 IAT but still might work. Here is a link to a thread that has a thread to the TPI IAT/MAT resistance vs. temp chart. https://www.thirdgen.org/forums/tpi/...mat+resistance
At 70F TPI IAT is 3400 ohms.
According to the Haynes manual I have for 93-00 f-bodies, the LT1 IAT at 70F is 2700 ohms. Much closer at 190F. TPI IAT is 260ohms, LT1 IAT is 240ohms.That's kind of a difference. ??? I don't completely trust the Haynes manual though.
Really its kind of a close call.
Here is a chart on the LT1 IAT sensor for comparision. Could do some temperature conversion calculations to make them match up to the TPI chart. http://shbox.com/1/4th_gen_tech2.html#ect
Old May 18, 2006 | 12:25 PM
Firebat's Avatar
I plotted the Data on a microsoft excel chart. You could probably use the TPI sensor.
Old May 18, 2006 | 12:36 PM
Firebat's Avatar
Here it is zoomed in at the temperature ranges from 40-120.
Old May 18, 2006 | 01:40 PM
Hey dude, thanks a lot, it was really helpful.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
Bert87
Aug 23, 2015 03:50 PM
redmaroz
Aug 16, 2015 11:40 PM
squiggy2
Aug 9, 2015 09:30 PM
